Activity Forums Apple Final Cut Pro Legacy Can’t installed FCP 5 on my G4 Powerbook
  • Can’t installed FCP 5 on my G4 Powerbook
    Posted by Luiggi Berrios on June 4, 2005 at 5:22 am
    I just got Final Cut Pro Studio 5 and when I try to installed the first cd of FCP app I get a Message that
    says that FCP cannot be installed in this computer because it don’t have the hardware requirements.
    My Powerbook is a G4 12″ with the following overview:
    Hardware Overview:
    Machine Model: PowerBook G4 12″
    CPU Type: PowerPC G4 (3.3)
    Number Of CPUs: 1
    CPU Speed: 867 MHz
    L2 Cache (per CPU): 256 KB
    Memory: 640 MB
    Bus Speed: 133 MHz
    Boot ROM Version: 4.5.5f4
    Serial Number: UV3032J8MRT
    AGP Graphic card
    GeForce4 MX:
    Type: display
    Bus: AGP
    VRAM (Total): 32 MB
    Vendor: nVIDIA (0x10de)
    Device ID: 0x0179
    Revision ID: 0x00a5
    ROM Revision: 2030
    Is there any workarounds on this problem, I need to digitize some HDV Video from a Sony FX1 camera and this only can be done with FCP 5.
    Luiggi Berrios replied 21 years, 3 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    June 4, 2005 at 2:52 pm
    You need to be running QT 7 and 10.3.9 or later to install… are you?
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Luiggi Berrios
    June 4, 2005 at 4:35 pm
    Yes I have Quicktime 7.01 Pro installed and my computer is running 10.3.9 system.
    Any suggestions?
