Activity Forums Media 100 Can’t install Quicktime 7.7
  • Can’t install Quicktime 7.7
    Posted by Erline O’donovan on September 2, 2011 at 11:12 am
    Hi all.
    I’m trying to install an update for Quicktime. I currently have version 7.6.6 and would like to install version 7.7 but when it comes to selecting the drive where I want to install it it says:
    QuickTime can’t be installed on this disk. This version of QuickTime 7 can’t be installed on this disk because QuickTime X is already present.
    I have OS X 10.6.8
    What can I do?
    Jaeson Koszarsky replied 15 years ago 3 Members · 2 Replies
  • Floh Peters
    September 2, 2011 at 2:49 pm
    QuickTime 7.7 is Leopard (10.5) only. There´s no way to install it on 10.6 and up.
  • Jaeson Koszarsky
    September 7, 2011 at 8:35 pm
    Just in case anyone is wondering about installing QuickTime 7.6 (not 7.7) under OSX 10.6.x, if they only have QuickTimeX, I did this not too long ago.
    You’ll need your install disc. Insert the DVD. When the Mac OS X Install DVD window appears, select the Optional Installs folder, then double-click the Optional Installs icon. When you get to the “Custom Install” list, you can pick QuickTime 7.
    Once installed, you will find QuickTime 7.6 in the Applications/Utilities folder.
    You can plug in your QuickTimePro activation code if you have one.
