Activity Forums Adobe Premiere Pro Can’t install Premiere Pro, stuck on installing redistributable package 2012
  • Can’t install Premiere Pro, stuck on installing redistributable package 2012
    Posted by Omur Sonmez on January 24, 2016 at 11:54 pm
    I have been having this problem installing Premiere Pro 2014 and 2015. Whenever it gets to installing the redistributable package of 2012, it gets stuck. I manually installed it myself, but still the install is stuck on that part. I restarted several times, uninstalled the redistributables, then reinstalled them. None of it seems to work.
    I also tried installing as an admin, still the same result.
    Tim Kolb replied 10 years, 6 months ago 2 Members · 1 Reply
  • Tim Kolb
    February 7, 2016 at 1:22 am
    Are you running McAfee with real-time scanning? If so, turn real-time scanning off and try the install again…
    TimK,
    Director, Consultant
    Video Producer at I-CAR
