Activity Forums DaVinci Resolve Can’t install DaVinci
  • Can’t install DaVinci
    Posted by Aleksandr N. on May 4, 2016 at 9:34 am
    Hi everyone
    After uninstallation of previous version (12.5b1) I can’t install DaVinci Resolve at all. Any Version including 12.5b2 and 12.3.2. After extracting of installer error message appears: “The feature you are trying to use is on a network resource that is unavailable”
    Screenshot: https://imagizer.imageshack.us/a/img924/6684/8Bo1d4.jpg
    and locating the file in temp folder doesn’t help either. The error message appears that “the file is not a valid installation package for DasVinci Resolve”
    Screenshot: https://imagizer.imageshack.us/a/img923/8965/0HrPMI.jpg
    Does anybody know a way to resolve this?
    Or where solution might be. Regisry, folders, permissions or anything to dig into
    System – Windows 10 x64
    -Aleksandr
    Steve Mullen replied 10 years, 4 months ago 2 Members · 2 Replies
  • Aleksandr N.
    May 4, 2016 at 12:11 pm
    Solution: I’ve found in the registry thread under HKEY_USERS where DaVinci installation info is stored and deleted it. Then everything worked as it should!
  • Steve Mullen
    May 18, 2016 at 2:27 am
    Curious, did you also use the Windows UNINSTALL control panel before trying to install a new version? If you did, I wonder why the Registry wasn’t cleaned.
