Can’t insert chapter markers to create DVD DL media
Nigel O’neill replied 12 years, 10 months ago 4 Members · 11 Replies
Nigel O’neill
November 23, 2013 at 11:47 pm[heinz melus] “What do you exactly: you put your rendered piece into DVDA and set it up in PREPARE DVD. What method of the second layer do you use? Parallel or opposite. “
I don’t. I just create my chapters in the DVDA timeline and then make up my menus. I have never been asked once to place a marker for the split. My version of DVDA (5.2) has never asked for it.
I also don’t use DVDA’s fit to disc, instead I use Mark’s bit rate calculator to work out the correct bit rate in Vegas for the render process.
