Activity › Forums › Apple Final Cut Pro Legacy › Can’t import quicktime files in FCP 6.0!
  • Benjamin Blois
    August 5, 2009 at 2:34 am
    I’m sorry, Tom. I’m not as technically literate as you are, no need to get upset.
  • John Pale
    August 5, 2009 at 2:41 am
    Guys…
    I know he’s trying to work with a file that will be problematic….but normally FCP will happily import an H.264 video (only to give you problems editing it later…).
    The error message (access denied) he’s getting seems to indicate he has a permissions issue.
    Benjamin, you should definitely convert this using Compressor to a more edit friendly codec (the ones they others suggested should be fine). You will find the presets self explanatory within Compressor.
    Did I read correctly that you cannot import ANY file? Where do the files you are trying to import reside?
  • Tom Wolsky
    August 5, 2009 at 2:50 am
    AAC audio can produce the same result. Any bets the other files are in the same format?
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
  • John Pale
    August 5, 2009 at 3:10 am
    [Tom Wolsky] “AAC audio can produce the same result”
    Didn’t know that. Never tried using AAC audio. Good to know.
    Thanks.
  • Neil Sadwelkar
    August 5, 2009 at 3:25 am
    Is it perhaps that you are trying to import a movie shot on a Canon T1i while the movie is still on the memory card. Meaning have you connected the camera to the system and are trying to edit a movie while its still in the camera?
    20 fps (yes twenty fps) h.264 is what Canon T1i shoots, and permission denied would be if the movie was still on the card in the camera?
    Just wild guessing.
    Neil Sadwelkar
    neilsadwelkar.blogspot.com
    twitter: fcpguru
    FCP Editor, Edit systems consultant
    Mumbai India
  • Tom Wolsky
    August 5, 2009 at 3:30 am
    Only in 1080. It does 30fps in 720, but either frame size you’d never want to to convert it to DV. That would be a horrible waste.
    All the best,
    Tom
  • Lisa Koza
    August 27, 2009 at 1:44 pm
    I just experienced this issue last night, and found my answer here on the COW, thanks!
    To add to the mysterious QT file, mine was a little different. I had previously worked on a project that required me to rip a DVD for some footage. I used the footage, no problem, it was fine. I delivered, ect. Months later they needed a change and I guess somewhere along the way the VOB files were deleted and I no longer had “access” to the quicktime mov, and couldn’t dump in final cut, and couldn’t reconnect my media. I converted it to DV, and reconnected the media, and everything worked fine.
    Just figured I’d help the next guy. 🙂
    Lisa
Page 2 of 2
