Activity › Forums › Apple Final Cut Pro Legacy › Can’t import QT Movie… why?
  • Can’t import QT Movie… why?
    Posted by Paul01 on January 8, 2006 at 6:24 am
    Somebody gave me a couple of Qicktime files that I need to import into my project.
    It isn’t working, there’s an error message saying: 1 file(s) recognized, 0 access denied, 1 unknown.
    If I try to open the QT file (open with) with FCP ist says: General Error
    I am using FCP HD 4.5, Quicktime 7.0.1
    I need those files, is there a setting that I need to change?
    Thanks in advance for all the help.
    Shane Ross replied 20 years, 8 months ago 3 Members · 10 Replies
  • 10 Replies
  • Shane Ross
    January 8, 2006 at 6:34 am
    What are the codecs of these QT files? They might be a format that FCP doesn’t work with.
    Shane
    Shane Ross
    Alokut Productions
    http://www.lfhd.net
  • Matthew Brunn
    January 8, 2006 at 6:35 am
    We need more information. Where did the files come from. What codec? Is it audio, video? Did these come from a PC? Can you open them in Quicktime? Can you open them with any app?
  • Paul01
    January 8, 2006 at 6:44 am
    I can open the files (Video and Audio) in Quicktime, I am not sure where they came from, Mac for sure, but probably FC Express 4.5 or 5. Will find out exactly tomorrow (it is late). Am I really tired or is there really no info on the codec in “get info”?
  • Shane Ross
    January 8, 2006 at 6:46 am
    You need to open the quicktime file and then look in the PROPERTIES – Apple J. Click on VIDEO.
    That shoudl tell you.
    Shane Ross
    Alokut Productions
    http://www.lfhd.net
  • Paul01
    January 8, 2006 at 6:48 am
    By the way, I can import them without problem into Affter Effects 6.0…
  • Paul01
    January 8, 2006 at 6:53 am
    OK:
    Video Track, Format H.264
    Sound Track, Integer (Big Endian)
  • Shane Ross
    After Effects isn’t codec dependant….as it is not a non-linear editing application that is expected to play back footage in real time. AE cannot playback in realtime…it needs to be rendered or for you to choose RAM PREVIEW.
    Shane Ross
    Alokut Productions
    http://www.lfhd.net
  • Shane Ross
    January 8, 2006 at 6:55 am
    H.264 is a delivery codec…not an editable one. You need to convert it to DV/NTSC using quicktime pro. Choose File>Export and choose the DV/NTSC codec. Then you can edit it.
    Shane Ross
    Alokut Productions
    http://www.lfhd.net
  • Paul01
    January 8, 2006 at 7:05 am
    Yes it works! Thanks for the quick answers!
    so cool…
  • Shane Ross
    January 8, 2006 at 7:11 am
    No problem. I was awake.
    I was amazed at the quality of the converted files. I too received masters in the H.264 codec to cut into a DV show…target was the web so the quality hit was minor.
    glad to help.
    Shane Ross
    Alokut Productions
    http://www.lfhd.net
