Activity Forums Adobe Premiere Pro Can’t Import PNG Logo to Timeline
  • Can’t Import PNG Logo to Timeline
    Posted by Ian Barrett on October 30, 2025 at 11:11 pm
    Cant import a logo as either PSD or png It keeps showing small icon of two columns with an arrow pointing downwards when I try to do this. Also the logo will show up but not any clips underneath it.
    Ive obviously hit a button wrong somewhere any ideas?
    Ian Barrett replied 10 months, 2 weeks ago 2 Members · 4 Replies
    October 31, 2025 at 12:37 am
    Hey Ian,
    We need a bit more information to be able to make suggestions.
    What version of PPro are you using + system hardware and software?
    When in Photoshop, does the logo have a transparent background?
    And is it in the RGB colour space?
    Hope this helps?
  • Ian Barrett
    October 31, 2025 at 5:37 pm
    Premiere pro 2021. Yes png has a transparent background as its a logo (have done this many times before successfully) I’m on a mac 11.7.10 (Big sur). Many thanks
    October 31, 2025 at 5:47 pm
    Hey Ian,
    Have you tried resaving the image as RGB in 8-Bit or 16-Bit Colour mode?
    The other obvious solution is for you to trash the preference and delete all render files.
    Maybe, set up a new project, and try to import the file there to see if that makes a difference?
    If you have it, take it straight into PPro Sequence via After Effects?
  • Ian Barrett
    November 1, 2025 at 12:14 pm
    Thanks, will give that a try
