cant import particular avi to vegas 10
hello all.
I’m using Sony Vegas 10 and I cant import a particular avi file.
When I try, no video shows up, no audio shows up.
Is there anyway to import or do i have to convert?
If I have to convert can you give me best quailty settings to use in “Xilisoft” or “Ojosoft”.
When I try to convert it allways turns out crapy.
Thanks in advance, J.
avi details:
General
Complete name : C:\saved stuff\vegas saves\gary franchi\originals\RealityReport-ObamasLibyanLies193.avi
Format : AVI
Format/Info : Audio Video Interleave
File size : 426 MiB
Duration : 27mn 16s
Overall bit rate : 2 181 Kbps
Writing application : Lavf50.6.0
Writing library : VirtualDub build 32706/releaseVideo
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L3.0
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : H264
Duration : 27mn 16s
Bit rate : 2 000 Kbps
Width : 720 pixels
Height : 400 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.232
Stream size : 398 MiB (94%)
Writing library : x264 core 112 r1834bm a51816a
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=abr / mbtree=1 / bitrate=2000 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=51 / qpstep=4 / crop_rect=0,0,0,0 / ip_ratio=1.40 / aq=1:1.00Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 27mn 16s
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Stream size : 25.0 MiB (6%)
Alignment : Split accross interleaves
Interleave, duration : 33 ms (1.00 video frame)
Interleave, preload duration : 500 ms
