Activity › Forums › VEGAS Pro › Can’t import mp4 files into VEGAS Movie Studio 16 Platinum
  • Can’t import mp4 files into VEGAS Movie Studio 16 Platinum
    Posted by Austin Ring on June 27, 2019 at 1:34 am
    The error basically says unsupported file format. I have tried using HandBrake to change the codec to MPEG-2 but it didn’t work ☹ Any help would be immensely appreciated.
    Here are the specs of the video from MediaInfo
    General
    Complete name : F:\Videos\int6.mp4
    Format : MPEG-4
    Format profile : Base Media / Version 2
    Codec ID : mp42 (isom/iso2/avc1/mp41)
    File size : 12.2 MiB
    Duration : 28 s 56 ms
    Overall bit rate : 3 636 kb/s
    Encoded date : UTC 2019-06-26 21:30:46
    Tagged date : UTC 2019-06-26 21:30:46
    Writing application : HandBrake 1.2.2 2019022300
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : Main@L4
    Format settings : CABAC / 4 Ref Frames
    Format settings, CABAC : Yes
    Format settings, Reference frames : 4 frames
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Duration : 28 s 28 ms
    Bit rate : 3 367 kb/s
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Variable
    Frame rate : 59.940 FPS
    Minimum frame rate : 59.920 FPS
    Maximum frame rate : 59.960 FPS
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.027
    Stream size : 11.3 MiB (93%)
    Writing library : x264 core 157 r2935 545de2f
    Encoding settings : cabac=1 / ref=2 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=6 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=18 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=600 / keyint_min=60 / scenecut=40 / intra_refresh=0 / rc_lookahead=30 / rc=crf / mbtree=1 / crf=22.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=20000 / vbv_bufsize=25000 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
    Color range : Limited
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Codec configuration box : avcC
    Audio
    Format : MPEG Audio
    Format version : Version 1
    Format profile : Layer 3
    Format settings : Joint stereo
    Codec ID : mp4a-6B
    Bit rate mode : Constant
    Bit rate : 256 kb/s
    Channel(s) : 2 channels
    Sampling rate : 48.0 kHz
    Compression mode : Lossy
    Stream size : 877 KiB (7%)
    Title : Stereo
    Writing library : LAME3.100
    Default : Yes
    Alternate group : 1
    Heidi Huff replied 7 years, 3 months ago 4 Members · 7 Replies
  • 7 Replies
  • Ole Kristiansen
    June 27, 2019 at 9:16 am
    Try again with Hanbrake convert to mp4 – but to constant frame rate !
  • George Dean
    June 27, 2019 at 1:25 pm
    Hi Austin,
    Can you upload a 10 second sample of your source media here, so we can try it?
    Best Regards……George
  • Austin Ring
    June 28, 2019 at 6:25 pm
    I have tried this multiple times, but thanks for the reply.
  • Austin Ring
    Yes, I’ll try this when I get home.
  • Ole Kristiansen
    June 28, 2019 at 6:46 pm
    What happens if you changed the file extension from .mp4 to .avc ?
  • Austin Ring
    June 29, 2019 at 3:42 am
    Nothing different.
  • Heidi Huff
    June 29, 2019 at 6:18 pm
    This is going to sound crazy. I don’t know why it works. But download Apple QuickTime onto your computer. Sony Vegas will then accept the mp4 files.
