Activity › Forums › Apple Final Cut Pro Legacy › Can’t import .mov file into Final Cut Pro.
Posted by Tammy Camp on May 12, 2010 at 1:09 pmHi everyone,
I have some footage that plays fine on QuickTime Player 7, however when I try to import it into Final Cut I get errors.
Please see the attached images.
Tammy Camp
Michael Gissing replied 16 years, 4 months ago 4 Members · 3 Replies -
Jerry Hofmann
May 12, 2010 at 2:53 pmIt’s likely some sort of corruption in the file itself. What was the source of the file? Is it DVCPROHD or?
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
Michael Gissing
May 13, 2010 at 12:12 amYou sequence setups look like a disaster. You are controlling a 1080 50i source, capturing as AIC and then running the sequence as ProRes HQ 1280 x 720 30p!
Firstly none of your settings match – codecs and frame rates. If you are capturing 1080 50i HDV footage, then don’t convert to AIC. If you want to convert, make it ProRes 422 1080 50i . The sequence must then match this setting, otherwise you are transcoding to a different frame size and frame rate. This will make it play back badly and require constant rendering.
So apart from why one file won’t load, you need to sort what your sequence settings should be based on your source footage and also what your final delivery is.
