Activity › Forums › Adobe After Effects › Can’t import .m2v
  • Can’t import .m2v
    Posted by Renee Matthews on October 12, 2012 at 7:52 pm
    I have an old .m2v video from a while ago when I was using CS5.
    I’ve upgraded to CS6 and now cannot import .m2v files into After Effects, or Premiere Pro.
    Any suggestions? I tried renaming to .mpeg which allows me to select the video to import but then it gives a decompression error.
    Any help is appreciated.
    Thank you
    Erik Waluska replied 13 years, 11 months ago 2 Members · 1 Reply
  • Erik Waluska
    October 13, 2012 at 11:36 pm
    Try .mpg instead of .mpeg. If that doesn’t work then you might need to convert to a different format.
