Activity › Forums › DaVinci Resolve › Can’t Import LUTS into Resolve
Posted by Matthew Mcmanus on August 10, 2011 at 7:07 pmI am having issues installing Arri Generated LUTs into Resolve for the Alexa. I have found the Application Support Library and placed the LUTs from the LUT generator Arri supplies. I don’t know if the files generated from Arri require some sort of translation as I have noticed the file types are different from the default LUTS in Resolve. Any suggestions would be helpful.
MatthewDwaine Maggart replied 13 years, 4 months ago 6 Members · 9 Replies -
Sascha Haber
August 11, 2011 at 1:06 pmDid you make the LUTs yourself ?
Check the LUT builder software again, maybe you did select a wrong entry.
They normally work perfectly fine.A slice of color…
DaVinci 8.0.1 OSX 10.7
MacPro 5.1 2×2,4 24GB
RAID0 8TB eSata 6TB
GTX 470 / GT 120
Extreme 3D+ WAVE -
Matthew Mcmanus
August 11, 2011 at 5:12 pmyeah i guess it’s a bit confusing, but I spoke to Blackmagic and depending on the LUT (1D or 3D) the LUT goes into a different folder. If the LUT has an extension of .cube, it goes in the Cinespace subfolder, for instance. There is a document explaining the different LUT designations and where they are to be placed the Blackmagic has. Apparently it is not intuitive.
Dwaine Maggart
August 11, 2011 at 9:15 pmUntil very recently, if you selected DaVinci Resolve as the file format on the Arri LUT builder web site, it made .dat LUTS, and those needed to go in the Arri folder.
But Arri has updated the app, and it now generates .cube LUTs when you select DaVinci Resolve as the file format. And .cube LUTs need to go in the Cinespace folder.
Dwaine Maggart
Blackmagic Design DaVinci Support -
Evans Briceño
November 22, 2012 at 3:25 amHello Mr. Dwaine. What About this two type of extensions:
.Lut
.3DL (Kodak proprietary)how can import them or at least, generate a compatible Lut for davinci.?
thanks.
Evans Briceño
BLUE films
Caracas, Venezuela.
VZLA. +584166352066 / +582122838114 / USA +1-718-673-3326
virtualevans@gmail.com / contacto@virtualevans.com / http://www.virtualevans.com -
Edo Brizio
April 17, 2013 at 8:01 pmI have the same question…can anybody answer?
how .lut created in scratch can be imported in Resolve? -
Edo Brizio
Evans Briceño
May 7, 2013 at 2:59 amHello Mr. Dwaine. What About this two type of extensions:
.Lut
thanks.
Evans Briceño
BLUE films
Caracas, Venezuela.Evans Briceño
BLUE films
Caracas, Venezuela.
Dwaine Maggart
May 7, 2013 at 4:03 amYou might take a look at this. It’s a free download, and you can convert a few LUTs with it, before you have to pay for it. This will allow you to see if it might convert your LUT formats to a DaVinci 3D .cube LUT format.
https://www.brizsoft.com/lut-editor/
Dwaine Maggart
