Activity Forums Avid Media Composer Can’t import folders into bins
  • Can’t import folders into bins
    Posted by Danielle Warren on August 28, 2012 at 7:59 pm
    Hi again!
    I was given folders full of folders and files of music, sound effects, and graphics from a client. I go to drag and drop the folders into separate bins in my avid projects (like I would in FCP), and I keep getting the error “The file format of (name of folder) is not supported for import.
    But when I just import an individual file from those folders, it comes across fine. That is not only incredibly time consuming, but would also mean I would have to re-organize all the existing folders in AVID if each file has to be brought in individually. Also, I can’t figure out how you make folders within bins either to even organize things in such a way.
    Thanks for the help. Sorry for being a newb.
    Christoffer Laubel replied 14 years ago 3 Members · 3 Replies
  • Job Ter burg
    August 28, 2012 at 8:20 pm
    Unfortunately, it doesn’t work like that in Avid. You can’t have folders inside bins, but you can have multiple folders in a Project, and each folder can contain bins and/or subfolders. You will have to manually create those, though, and you can only bring stuff into a single bin at a time.
  • Danielle Warren
    August 28, 2012 at 8:23 pm
    Argh. Thanks Joe. That’s very frustrating, but thank you for clearing it up.
  • Christoffer Laubel
    August 30, 2012 at 8:45 am
    In the import dialogue, you can select more than one file.
    Navigate to the windows folder, select all files in the folder with Ctrl+a.
    Press OK.
