Activity Forums Maxon Cinema 4D can’t import eps
  • can’t import eps
    Posted by Picxsee on July 21, 2006 at 1:21 am
    Hi… i’m a super newby (first time ive opened it) to cinema 4d and i know there must be a simple answer to this, but… I can’t seem to import an eps with a simple outline in it.
    In the objects pallete i choose file > load object and choose the file and it just doesnt show up in the objects pallete???
    Wots the deal? I can put other stuff like lights etc but the eps… no show.
    Ideas please? ta x
    Picxsee replied 20 years, 1 month ago 2 Members · 7 Replies
  • 7 Replies
  • Nolan Scott
    July 21, 2006 at 1:49 am
    Well, I presume you
  • Picxsee
    July 21, 2006 at 2:40 am
    Thanks so much for the speedy reply!
    I have actually tried that with no luck. I’ve also tried drawing it in freehand and saving it out as an eps from there. Same prob. Hence the ???
    Any other ideas would be greatly appreciated!
    Thanks again x
  • Nolan Scott
    July 21, 2006 at 3:34 am
    Not sure why it doesn
  • Picxsee
    July 21, 2006 at 3:38 am
    Hi Nolan,
    Ahh… had tried an .ai but not a previous version… that worked! Strange that the eps’s aren’t though isnt it. Could it be some setting in Cinema 4d?
    Thanks again 🙂
  • Picxsee
    July 21, 2006 at 3:39 am
    ps the eps’s are not even showing up in the objects pallete let alone on the stage.
  • Nolan Scott
    July 21, 2006 at 5:25 am
    Well, I hope you haven
  • Picxsee
    July 23, 2006 at 10:53 pm
    Hi and thanks again Nolan… The illustrator preferences were already set that way, and yes definately not importing eps files, early illustrator versions or freehand. V odd isnt it.
    If you have any other thoughts bout what it could be let me know 🙂
    Cheers x
