Activity Forums Adobe Audition can’t hear output
  • can’t hear output
    Posted by Ralph Bertini on December 20, 2006 at 3:52 pm
    Just installed audition on my xpro 4.6 with mojo system. XW 8200 with all approved components. I imported a clip into audition and voila its there, I see the meters bouncing but I can’t here any audio thru my system. I’ve looked all thru the audition interface looking for some settings to see if there’s a place to select where audio comes in/out. Any help is always greatly appreciated. Happy Holidays – Ralph
    Willie Toth replied 19 years, 8 months ago 2 Members · 1 Reply
  • Willie Toth
    December 20, 2006 at 5:43 pm
    Ralph,
    There are a couple of places you need to check … Go to OPTIONS > DEVICE ORDER and see what your defaults are for your playback … Do you have multiple sound cards or just one? Did you try the playback in the session side or the edit side? If you were on the session side and using multiple sound cards make sure your tracks are set properly, you can do this by clicking the box marked out at the side of the track … I hope this helps ……… WILLIE
