Activity › Forums › Apple Final Cut Pro Legacy › can’t hear audio while capturing
Posted by Rob on December 29, 2005 at 8:14 pmI’ve had this issue before and can’t seem to recall how i managed to fix the problem before. Under clip settings i have both audio & video selected. I’ve also tried changing the audio playback settings under audio and video setttings but still no luck…Any suggestions?
RobKevin Monahan replied 20 years, 9 months ago 3 Members · 3 Replies -
Kevin Monahan
December 29, 2005 at 8:20 pmIt’s best to simply connect your speakers to your your deck and not the Mac. You’ll always be able to monitor audio that way.
Many people do not do this.
Kevin Monahan
Take My FCP Master’s Seminar!
fcpworld.com -
Bouncing Account needs new email address
December 29, 2005 at 8:32 pmKevin is exactly right.
This is a VERY frequently-asked question.
You can find answers in seconds if you will use the “Search Posts” function here on the COW.
—————————————————————The audio is, by default, intentionally MUTED to the Mac’s speaker output during Log and Capture.
So you should normally monitor the audio directly from the camcorder or deck you are using to capture. (It is the preferred method.)
CAUTION:
Many people have reported that noise or “pops” appear in the captured clips if the Mac’s internal audio is left on WHILE capturing… so may want to choose “Off During Capture.”However, there is a way you can turn ON the Mac’s speaker if you really WANT to:
In FCP4x and earlier:Final Cut Pro (menu) > Audio/Video Settings… > Capture Presets (tab)
“Duplicate” the Capture Preset you are now using, when the window opens rename it (I added “MacAudioOn” to the file name).
Click open the “Advanced” button in the Audio section and turn speakers to “ON during Capture.”
The Mac speakers/audio-out will now play Audio during the preview in the Log and Capture window.
In FCP5x and later:In the Record Tool:
Clip Settings, near audio buttons, choose: Preview: “ON”
Kevin Monahan
December 29, 2005 at 8:34 pmYou said it pot’na. Proper audio (and video) monitoring the #1 confusion for all FCP greenhorns.
Kevin Monahan
fcpworld.com
