Activity Forums Adobe Premiere Pro can’t hear audio after speed duration change/ CS5
  • can’t hear audio after speed duration change/ CS5
    Posted by Mark Elf on May 8, 2011 at 6:08 pm
    My audio plays fine before I make a speed duration change but as soon as I make that change I can’t get any sound when I go to play it back. I know it’s something dumb I must be doing but I sure can’t figure it out ! Any help would sure be appreciated !!
    All other edits like this that I’ve done before I’ve had no problem with and now all of a sudden this issue.
    Mark
    Mark Elf replied 15 years, 3 months ago 3 Members · 5 Replies
  • Jay Kinghorn
    May 10, 2011 at 11:57 am
    Mark,
    Try rendering the clips on your timeline and see if that helps.
    Best regards,
    Jay
  • Mark Elf
    May 10, 2011 at 1:55 pm
    Hi Jay: thanks for the suggestion. The crazy thing is that I figured out that when I can slow down the video up to 45% with the hold original pitch box checked it will work. I need to have the “hold to original pitch” box checked because I am editing music education videos.
    If I slow it down to 44% or less the audio won’t play ! I can slow it down 44% or less without the “hold to original pitch” box checked and the audio will work but of course the pitch is wrong ! That’s no good for me.
    So that check box is the problem. I wonder if it’s a bug. I was using premier elements and could slow down the video and audio as much as I wanted and never had a problem.
    I am still puzzled by this.
    Thanks very much for responding
    Mark Elf
  • Jay Kinghorn
    May 10, 2011 at 3:15 pm
    Mark,
    That’s very strange. About the only time I have to render anything on the timeline in PP is when I have multiple audio tracks, audio effects or bring in audio tracks at 32bpc.
    Thanks for the head’s up about the checkbox!
    Jay
  • Tim Linn
    May 19, 2011 at 2:48 am
    I’m experiencing the EXACT same issue. I’m trying to speed up a clip to 104%. I get audio just fine if I DON’T check “maintain audio pitch”. Once I do, no audio. I assumed I must be doing something wrong but given that you’ve got the same issue it must be a bug. Of course, knowing this is of no help to solving the problem… Frustrating.
  • Mark Elf
    May 19, 2011 at 4:24 am
    Now the crazy thing is I’ve slowed down a different video to 30% checked the “maintain original pitch” box and there was no problem. It must be something in the video or all the presets you choose as you start a new project.
    I’m not a pro editor and don’t know CS5 very well at all, the truth be told, so I really can’t say what’s going on.
