Activity › Forums › Apple Final Cut Pro Legacy › Can’t hear anything!
  • Can’t hear anything!
    Posted by Doug Collins on November 15, 2005 at 6:58 pm
    I’ve finally gotten to the point where I can encode video and audio into FCP. Unfortunately I can’t hear the audio (just barely if I hold my head reeeeeeally close to the speakers). The levels are moving on the meter so I know it’s there. The audio levels on the powerbook is up all the way so it can’t be that (can hear normal audio on other programs).
    Any suggestions?
    Thanks for the help,
    Doug
    Doug Collins replied 20 years, 10 months ago 2 Members · 2 Replies
  • Rob Forsythe
    November 15, 2005 at 7:10 pm
    This is a VERY frequently-asked question.
    You can find answers in seconds if you will use the “Search Posts” function here on the COW.
    The audio is, by default, intentionally MUTED to the Mac’s speaker output during Log and Capture.
    So you should normally monitor the audio directly from the camcorder or deck you are using to capture. (It is the preferred method.)
    CAUTION:
    Many people have reported that noise or “pops” appear in the captured clips if the Mac’s internal audio is left on WHILE capturing… so may want to choose “Off During Capture.”
    However, there is a way you can turn ON the Mac’s speaker if you really WANT to:
    In FCP4x and earlier:
    Final Cut Pro (menu) > Audio/Video Settings… > Capture Presets (tab)
    “Duplicate” the Capture Preset you are now using, when the window opens rename it (I added “MacAudioOn” to the file name).
    Click open the “Advanced” button in the Audio section and turn speakers to “ON during Capture.”
    The Mac speakers/audio-out will now play Audio during the preview in the Log and Capture window.
    In FCP5x and later:
    In the Record Tool:
    Clip Settings, near audio buttons, choose: Preview: “ON”
  • Doug Collins
    November 15, 2005 at 7:56 pm
    Sorry I wasn’t clear, I couldn’t hear during capture (and thanks for clearing that up). The problem I was talking about was hearing the audio during playback after capture. I did a search and finally (MAN there are a lot of posts in this forum!!) and found the answer.
    Doug
