Forums Adobe After Effects Expressions Can’t get xRotation value of another layer in After Effects
  • Can’t get xRotation value of another layer in After Effects
  • Shaun Thomson
    July 13, 2021 at 1:42 pm
    I have two layers – a leader and a follower.
    I’m successfully able to make the follower follow the leader with this expression in the follower’s Position property:
    src=thisComp.layer("Leader");
    delay = thisComp.layer("Leader").effect("Delay")("Slider");
    d = delay*thisComp.frameDuration*(index - 1);
    src.position.valueAtTime(time - d);
    I can also make it follow the leader’s orientation with this expression in the follower’s Orientation property:
    src.orientation.valueAtTime(time - d);
    However, when I try to make the follower follow the leader’s xRotation with the following in the follower’s xRotation property, I get an error:
    src.xRotation.valueAtTime(time - d);
    The error:
    Cannot read read property 'valueAtTime' of undefined
    The code works fine for the other properties – why not the xRotation?
    The leader definitely has xRotation keyframes in it.
    Thank you
  • Dan Ebberts
    July 13, 2021 at 2:58 pm
    Try it this way:
    src.transform.xRotation.valueAtTime(time – d);
  • Shaun Thomson
    July 14, 2021 at 2:50 am
    Thank you Dan. It’s throwing a syntax error now. I can’t find anything wrong with the syntax though – is anything obvious sticking out please?
    src=thisComp.layer(“Leader”);
    delay = thisComp.layer(“Leader”).effect(“Delay”)(“Slider”);
    d = delay*thisComp.frameDuration*(index – 1);
    Error: missing ) after argument list
  • Dan Ebberts
    July 14, 2021 at 3:31 pm
    Once I fixed the mangled quotes and minus signs (which happens in this forum if you don’t use a preformatted text box to post code), it seems to work fine. This should be OK:
    src.transform.xRotation.valueAtTime(time - d);
Viewing 1 - 4 of 4 posts
Log in to reply.
