Activity › Forums › Adobe Premiere Pro › Can’t get tracks laid out logically
Posted by Michael Krupnick on January 6, 2012 at 8:55 amI’m trying to do something really simple everywhere else, but PP is being just stoopid. I have multiple takes I want to stack and sync. PP won’t let me put the audio where I want. what gives?
Kevin Monahan replied 14 years, 7 months ago 6 Members · 6 Replies -
Jon Barrie
January 6, 2012 at 11:47 amIf you maneuver your video clip to the track you want and hold the shift key down, you can then maneuver the audio elements to the track you want by pointing to the track you can the first element to drop onto.
Hope this helps,
Cheers JB
PS: Make Heaps of Audio Tracks in advance. Right click over the track names, select Add Tracks and hit in a value of about 16, that sound keep you going for a while 🙂
Jon Barrie
Adobe Video Solutions Consultant ANZ
Jon’s YouTube Tutorial Page
follow Jon with twitter -
Michael Krupnick
January 6, 2012 at 1:09 pm -
Tero Ahlfors
January 6, 2012 at 3:47 pmNote that the audio tracks 1-3 are stereo. They wont take mono audio.
Paul Neumann
January 6, 2012 at 4:16 pmControl/Right click on any audio track name, check “delete audio tracks”, select “all empty tracks” and from there on just drag any track below the master track and a compatible track will be created in succession.
Tero Ahlfors
January 6, 2012 at 6:27 pmYou can also right click the file in the project panel and pick modify -> audio channels to map the mono tracks into stereo if you want. Note that you can’t modify the audio channels if the file is already cut in to a timeline.
Kevin Monahan
January 6, 2012 at 6:59 pmOn our FAQ list. Here’s the video that will help: https://www.video2brain.com/en/videos-4009.htm
More FAQs: https://forums.adobe.com/community/premiere/faq_list
Kevin Monahan
Sr. Content and Community Lead
Adobe After Effects
Adobe Premiere Pro
Adobe Systems, Inc.
Follow Me on Twitter!
