Activity Forums Boris FX Can’t get stabilizer with Sony Vegas to work
  • Can’t get stabilizer with Sony Vegas to work
    Posted by Jan Van bekkum on September 8, 2007 at 9:19 pm
    If I want to stabilize a scene by launching Boris FX from Vegas, I get only a still in Vegas. Vegas does the analysis, but doesn’t find the movements. The result is the same as the original file. Any clue what I do wrong?
    Jan Van bekkum replied 18 years, 11 months ago 2 Members · 2 Replies
  • Peter Honig
    September 13, 2007 at 5:24 pm
    The problem is that Vegas only supplies single images to plugins instead of entire clips. This is true for all plugins. The work-around is to:
    1. Render from Vegas the small clip that you want to pass to FX.
    2. Add the FX plugin to the clip (if you have not already done so).
    3. Enter Boris FX and look for the video that came from Vegas (it will be a reference to media “V1”).
    4. Replace the reference to “V1” with the name of the clip that you rendered in step 1.
    5. Proceed as usual. The results from FX will be automatically returned to Vegas. That is, no additional rendering “tricks” are needed.
  • Jan Van bekkum
    September 16, 2007 at 6:59 pm
    Thanks a lot, this works fine.
