Activity › Forums › Adobe After Effects Expressions › Can’t get Source Text parameter to execute 2 expressions.
  • Can’t get Source Text parameter to execute 2 expressions.
    Posted by Daniel Annefelt on October 5, 2020 at 7:39 pm
    Hello genius people!
    Running AE 17.1.4 with JavaScript enabled,
    I have two simple expressions on the Source Text parameter.
    The first expression retrieves text input from another layer in a separate Comp.
    ______
    comp(“CHANGE TEXT”).layer(“1 Line Small Text”).text.sourceText
    ______
    The second expression changes between two fonts of the text based on a Expressions Checkbox effect.
    ______
    if (comp(“CHANGE TEXT”).layer(“Layout_Selector”).effect(“Comedy Central”)(“Checkbox”) == 1)
    (text.sourceText.style.setFont(“AmericanTypewriter”))
    else
    (text.sourceText.style.setFont(“Helvetica”))
    ______
    Each expression works like a charm when using one or the other.
    But when combined – which is my goal – it stops retrieving the text from the other layer.
    ______
    else
    ______
    Obviously there is some syntax missing that tells the Source Text to do two things
    – get text from another layer and check what font to use based on the checkbox.
    But my merger expressions skills can’t crack this.
    Does anyone have a solution to this or is a current AE cc2020 limitation
    cheers!
    .::D
    Yerko Alarcón replied 5 years, 11 months ago 3 Members · 5 Replies
  • Dan Ebberts
    October 5, 2020 at 8:04 pm
    This should work:
    txt = comp("CHANGE TEXT").layer("1 Line Small Text").text.sourceText.value;
    cb = comp("CHANGE TEXT").layer("Layout_Selector").effect("Comedy Central")("Checkbox").value;
    myFont = cb ? "AmericanTypewriter" : "Helvetica"
    style.setFont(myFont).setText(txt)
  • Daniel Annefelt
    October 5, 2020 at 8:14 pm
    Haha! Ok, overlord expression master – that worked.
    I kind of see what you did – define two variables and then mash them together.
    But most is gibberish to me.
    What does the “?” do and how does the “:” work to define the two options?
    Regardless – super thanx! You guaranteed me at least another months employment.
    Dinner and drinks on me next time you hit Stockholm!
    .::D
  • Dan Ebberts
    October 5, 2020 at 8:24 pm
    That’s the JavaScript ternary conditional operator. It’s a compact alternative to if/else that I like because you can put it on a single line without having to add curly braces.
  • Daniel Annefelt
    October 5, 2020 at 8:34 pm
    Compact and elegant.
    .::D
  • Yerko Alarcón
    October 6, 2020 at 2:35 am
    Hello, Dan! You can help me my equal, I have seen that you are an expert. This happens to me when I open After Effects.
    Message:
    “Unable to run script on line 1. Expected :)”
    Please help me, thank you very much.
    Greetings Yerko
