Activity › Forums › Apple Final Cut Pro Legacy › Can’t get Smoothcam working with XDCAM or ProRes???
Posted by Andrew on September 15, 2009 at 4:24 amHi guys,
Was wondering if anyone has had success applying smoothcam successfully to either XDCAM or Prores footage?
I shot on an EX3 using the 720P format and cannot see any ‘smoothness’ in applying the filter to either type of footage?
I have adjusted the settings and understand how they work but am not getting any results.
Any info is greatly appreciated.
CheersJeremy Garchow replied 16 years, 11 months ago 3 Members · 7 Replies -
Jeremy Garchow
September 15, 2009 at 1:07 pmDo you mean that if you open the background processing window after applying the effect, nothing happens?
Jeremy
Rafael Amador
September 15, 2009 at 1:44 pm -
Andrew
September 15, 2009 at 9:18 pmMaybe I tell you exactly what I did…
I converted the handheld 720P XDCAM to ProRes 422, then brought that in on a ProRes timeline. Adjusted settings to Smoothcam then dropped it on for analysis. Once analysing was complete I renedered the green out to blue and saw no changes.
My Smoothcam settings were:
Auto Scale 1
Transitional Smooth 3
Rotation Smooth 3.5
Scale Smooth 0
Mix 100I’ve had success with smoothcam using SD DV but none with the XDCAM/ProRes.
Jeremy Garchow
September 15, 2009 at 9:35 pm -
Andrew
September 15, 2009 at 9:42 pmNope. That wasn’t it, but this is interesting…
I see what you mean about the mix value. The strange thing is, when I did that on the original clip nothing happened. But when I copied the file to a new timeline to make you a short clip, I could see the mix value change. (That sort of overlay ghosting).
So I went back to my original timeline and reduced the length of it and presto I could see the two mix values. But when I extend the clip back to its original length, I don’t get any smoothcam???
What is this telling me?
That I need to increase my Transition & Rotation Smooth values or something else? -
Andrew
September 15, 2009 at 9:45 pmBTW, the clip does include graphic/photo overlay in it that doesn’t require the smoothcam. Could that be an issue?
Jeremy Garchow
September 15, 2009 at 9:48 pm[Andrew Mula] “Could that be an issue? “
Yes, it could be. I rarely adjust the Smoothcam parameters once it’s done working.
