Activity Forums Adobe Photoshop Can’t get out of “FAUX BOLD” setting on fonts!
  • Can’t get out of “FAUX BOLD” setting on fonts!
    Posted by Stu Aull on October 23, 2005 at 9:25 pm
    Hi folks-
    Like the title sez! I am typing in words in Phsp.6.0.1 and ALL the fonts are typing in CAPS?! Can’t find a menu item, style or preference to knock this out! Help! Try to use the Warped Text feature, I get the alert:
    “Cannot complete your request because typed layer uses a faux bold style”
    Thanks in advance!
    Stu Aull
    Alaska
    Kalleheikki Kannisto replied 10 years, 7 months ago 5 Members · 5 Replies
  • Kim Mackenzie
    October 23, 2005 at 9:38 pm
    Yeah, faux bold is kind of hidden – this is a common annoyance (happens to everyone once).
    Bring up the Character palette
    Click the little arrow in the upper right of the palette to access the flyout menu.
    Uncheck Faux Bold
    Ta da
  • Richard Harrington
    October 23, 2005 at 11:01 pm
    Look at character palette
    Richard M. Harrington, PMP
    Author: Photoshop CS for Nonlinear Editors
    Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
    Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
    edit – produce – direct –
  • Stu Aull
    October 24, 2005 at 12:13 pm
    “ta – da” Indeed!
    Oh-so-obvious when you know where to look!!! 🙂
    Thanks fellas!
    regards’
    Stu Aull
  • Sharlene Plescia
    January 18, 2016 at 5:12 pm
    I am still using photoshop 6.0 because I can’t afford to buy the newer versions. However, that is fine…it really is all I need.
    I followed several suggestions to remove the faux bold setting in Character, however, after I reset that, I still cannot use the shape tool for text. It STILL says can’t use due to faux bold setting. Help????
  • Kalleheikki Kannisto
    January 21, 2016 at 10:53 am
    By “shape” tool, do you mean “warp text”?
    Considering it should work once you’ve removed faux bold, can you upload a file that you have this problem with?
