Activity Forums Adobe After Effects can’t get my layer to turn on to be viewed
  • can’t get my layer to turn on to be viewed
    Posted by Craig Johnson on November 5, 2013 at 4:32 am
    trying to make a simple project to add to a FCP project. I have 19 layers that I was making to zoom from a house to outer space. I had scaled and parented the stills when I noticed I had a still with different dimensions so the aspect was goofed up. I deleted and resized in Photoshop and put it back in line for scaling and parenting. I go into the comp and click on my repair and it works fine. I can see it, play with opacity, etc…when I click the eye on for any of the other stills, I can’t see them to work on them. I took the parenting feature off and still can’t. I tried the custom view to active camera and nothing. Do I have to start over? This is AE 5.
    Todd Perchert replied 12 years, 10 months ago 2 Members · 3 Replies
  • Craig Johnson
    November 6, 2013 at 12:05 am
    Thanks for responding Dave. I tried that already. That’s not it.
  • Craig Johnson
    November 6, 2013 at 2:39 pm
    Figured it out. Somehow when I saved the project and reopened it, the scale on each of the layers had set to zero. Still trying to get how that happened. Thanks.
  • Todd Perchert
    November 6, 2013 at 3:32 pm
    I’ve had that happen in CS5 before, usually on keyframes, and the first keyframe would somehow change to a scale value of zero. Could never figure that one out. Happened a few times. Haven’t seen it in CS6.
    TC
