Activity Forums Blackmagic Design Cant get Intensity Pro to output RGB:(
  • Cant get Intensity Pro to output RGB:(
    Posted by Ben Edwards on May 19, 2010 at 11:46 pm
    I borrowed a Sony 14″ PVM 1444QM monitor and liked it so much purchased a 14″ PVM 2042QM thinking it was basicaly the same monitor, but I was wrong.
    The 1444QM has a component/RGB switch and I had it set to component to get it working with the Intensity Pro using the component connectors. The 2042 seems to only be able to handle RGB (There is no switch and button on front is labeled RGB)) and I cant get it working with the Blackmagic Intensity Pro card.
    Any ideas?
    Ben
    Kristian Lam replied 16 years, 4 months ago 2 Members · 2 Replies
  • Ben Edwards
    May 20, 2010 at 1:25 am
    Sorry, I meant a 20″ PVM 2042QM not 14″.
  • Kristian Lam
    May 20, 2010 at 1:36 pm
    Intneisty Pro’s output is component YUV and does not support RGB.
    regards
    Kristian Lam
    Blackmagic Design
