Can’t get edited clip back to full size
Hi, i’m using FCP 4.5. I got a project involving clips shot from 2 different angle from 2 cameras.
To make it easier during the edit process, i took both clips in the time line. To be able to see them, i’ve reduced their size and placed them side by side. AFTER I did my cuts.
Now the fun begins…At this point, i want my clips to recover there full size and the original anchor point in the canvas. So i selected each track, one at a time and tried to make the change back to the original. Coudn’t use the animation palette with one whole track selected after the cuts are done.
The only and painful way i’ve found this far is to select each individual edited clips and make the change trough animation palette. And like if it was not painful enough, i accidently put a filter wich was applied to the whole track. How can i get rid of the effect?
Thanks for considering this request. I’m a fairly new FCP user.
