Activity Forums AJA Video Systems cant get DV to play out of konaSD, only freeze frames…
  • cant get DV to play out of konaSD, only freeze frames…
    Posted by Paul Harb on April 28, 2005 at 10:39 pm
    NOt sure why but for some reason all of the sudden I cant get my DV timeleine to play out of my KonaSD card to my NTSC monitor, it refreshes to the current frame when I stop playback, but when I hit play, it stays on the last frame until I stop play again at which point it refreshes the frame…I had it working before, any ideas?
    Paul
    Walter Biscardi replied 21 years, 4 months ago 5 Members · 7 Replies
  • 7 Replies
  • Walter Biscardi
    April 29, 2005 at 2:19 am
    Sounds like you’re not in “Fit to Window” on your Canvas window.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
  • Paul Harb
    April 29, 2005 at 3:45 am
    checked that, not sure whats going on…never happened before…thks though..
    Paul
  • Peter Mcauley
    April 29, 2005 at 12:46 pm
    Check that under View>External Video>all frames is checked instead of single frames.
    Peter McAuley
    Axyz Edit
    Toronto
    G5 dual 2.0
    4 gigs ram
    10.3.8
    FCP 4.5 HD
    QT 6.5.2
    Kona 2 v1.0.5 with K Box
    4 X 250 gig external F800 Lacie firewire drive
    2 X 23″ Apple cinema display
  • Pierson Jacquelin
    April 29, 2005 at 7:38 pm
    This happened to me and a restart cured it.
    -Pierson
  • Paul Harb
    April 29, 2005 at 10:55 pm
    checked that as well….no go….really frustrating…
  • Steve Covello
    April 30, 2005 at 1:11 pm
    Had this problem on an HD test where I captured 1080i uncompressed, then transcoded the media file to DVCPro HD, then imported the new file. Same problem as you described occurred. However, if I changed the Easy Setup to the native 1080i DVCPro setting, it played fine. [don’t ask why I did thid crazy test – I just wanted to see the difference in quality and file size]
    I’m guessing that the K2’s hardware activates certain functions related to un-compressing video for display only when the appropriate setup is selected rather than autodetecting the kind of footage you are playing.
    I would say that if your DV footage is not playing, try using the native DV NTSC setup just to get it to play, then try other settings. Also, check the playback settings in the timeline and put it to Highest quality. If no luck, do a Panther Cache Cleaner zap at MEdium Cleaning for all caches.
    Steve Covello
    double wide post
  • Walter Biscardi
    April 30, 2005 at 1:29 pm
    [weevie833] “I would say that if your DV footage is not playing, try using the native DV NTSC setup just to get it to play, then try other settings. “
    Actually, that’s a great point, change your Easy Setup to DV-NTSC and it should work fine. I find that anytime I get the K2 not playing back footage correctly, I default back to an Easy Setup and it generally cures the issue.
    Good point weevie.
