Activity Forums Adobe InDesign Can’t get default font for new text boxes.
  • Can’t get default font for new text boxes.
    Posted by John Perez on June 27, 2015 at 6:35 pm
    It is allowing me to set my new default font for the entire document, but when I create a new text box it defaults to a different font.
    As always thanks so much to you guys…Johnny In Orlando
    John Perez replied 11 years, 2 months ago 2 Members · 2 Replies
  • Dwayne Smith
    June 28, 2015 at 5:45 am
    Select your text tool.
    Make sure no text frames are selected.
    Select the font/size/etc. you want as default in your control panel.
    (alternatively, select a paragraph style from the para styles panel).
    Now draw a text frame. You’ll see it matches the default you set.
  • John Perez
    June 28, 2015 at 9:02 pm
    I’ve been using the Rectangle Frame Tool then double clicking inside it which brings up another font. So I should be using the Text Tool whenever I have text and use the Rectangle Frame Tool for graphics and such. Got it. Thanks so much for reply…
