Activity Forums Adobe Encore DVD Can’t get audio on the same track…
  • Can’t get audio on the same track…
    Posted by Mark Pybus on May 15, 2007 at 3:52 pm
    Hi There,
    I’m having an issue where I cannot add another file to the end of my current timeline – or rather, I can, but only video and not audio. If a create an additional audio track, then the audio will show up. I am unable to get the audio for both files on the same track. This is the first time I’ve experienced this issue and it’s very frustrating.
    Hope I was clear. Any input would be greatly appreciated.
    Jeff Bellune replied 19 years, 3 months ago 2 Members · 3 Replies
  • Jeff Bellune
    May 15, 2007 at 3:55 pm
    Is the audio perfectly matched to the other audio on the track – format, channels?
    -Jeff
    The Focal Easy Guide to Adobe Encore DVD 2.0
  • Mark Pybus
    May 15, 2007 at 4:03 pm
    Hi Jeff,
    I’ve encoded my files as .mpg before I imported them into Encore. Interestingly, I’m only having a problem with the most recently encoded file, but as far as I know, I’ve done nothing differently – same workflow as always – export from Avid, encode and import into Encore.
    Are there any specific audio issues that you think might be causing the problem?
  • Jeff Bellune
    May 15, 2007 at 4:29 pm
    The first place I’d check is the number of channels – did you export as stereo when it should have been mono, or vice-versa?
    Additionally, if you are exporting as a muxed .mpg file, please consider exporting as demuxed, elementary .m2v video and .wav audio files. Things generally go much smoother in Encore when the imported assets are demuxed.
    -Jeff
