Activity Forums Live Events & Streaming Cant get Audio Inputs to work with Panasonic AG-HMX100
  • Cant get Audio Inputs to work with Panasonic AG-HMX100
    Posted by Josh Figatner on August 4, 2011 at 12:07 am
    Hello,
    I’ve recently been working with Panasonic’s AG-HMX100 HD Video switcher and I’m running into an audio difficulty:
    I’m able to hook up/switch between multiple cameras via HDSDI no problem, but I cannot get a signal from the XLR audio inputs. I have a shotgun mic hooked up via an XLR input port on the back of the switcher and can’t get a signal. When I connect the XLR to one of the cameras, I can get a signal no problem through the embedded SDI signal.
    This is not ideal as to get audio from an audio board, for example, I’d need to go from the board to the camera via XLR and THEN to the HMX100 via SDI. I’d much rather go straight to the HMX100 via XLR.
    I tried all the combinations of a/v inputs in the menu as well as assigning the L & R channels and “Audio Fader Mode”. I still can’t seem to get it to just take the XLR Audio In instead of the SDI audio in. The most promising setting is setting the audio source for any particular video source to “analogue” in the A/V settings menu. But still silence.
    Does anyone successfully use the XLR Audio In on the AG-HMX100? I’m curious about your settings & experiences.
    Thank you!
    Josh
    Rudolf Bom replied 6 years, 4 months ago 8 Members · 7 Replies
  • 7 Replies
  • Joel Hufford
    August 4, 2011 at 7:21 pm
    Hey Josh,
    I’m wondering what kind of shotgun microphone you’re using to test this setup?
    I don’t believe that the audio inputs on that mixer provide phantom power, so if you’re using a condenser style microphone, that would explain the silence.
    I’m also willing to bet that the phantom power on your camera is on, which is why it works no problem when you put the camera back in the signal path.
    You’re definitely on the right path with flipping the audio input setup to ANALOG. If you have a dynamic microphone available, like a Shure SM-58, try plugging that into the HMX with the input set to analog and see if it’s any different.
    Good Luck!
    joel
    Corporate and Special Event Staging Services
    http://www.pacificstaging.com
  • Brian Palmer
    September 7, 2011 at 1:57 pm
    Josh,
    Have you had any luck? I’m running into the same situation…Can’t seem to find anything in the manual that came with it. I’m getting a feed from our sound guy from a professional board.
    -Brian
  • Jonathan Barnes
    February 29, 2012 at 10:02 pm
    I have the same issue with the XLR inputs.
    We have tries nfeeding it a tone on ch 1 right & left, ch. 1 right ch. 2 left and even stuck a sm57 on it and nothing is coming through on the meter display of the switcher. and nothing to the outputs.
  • Jelle Didden
    February 26, 2013 at 11:31 am
    Does anybody have a solution? I’m having the same issues, no audio via the XLR inputs…
  • Jon Harrison
    January 23, 2017 at 7:23 pm
    Anyone ever resolve this? I’m having the same issue – I had no idea this was a problem.
    Jon
  • Jeff Busha
    March 11, 2019 at 2:39 pm
    Old thread, same problem . . . had it working at an event a couple months ago.
    Set up unit for an event this past weekend, using exact same ports as last event, and couldn’t get audio in from XLR input. Ended up using audio from Camera 2 described below.
    From what I recall, “Audio/Video” setup function did not allow me to choose Analog audio for source 1. And when changing audio input, system was changing video input as well? Very confusing!
    Setup as follows:
    Camera 1 uses HDMI input #1 as source 1
    Camera 2 uses SDI input #2 as source 2
    DVD Player for displaying slide show between acts uses HDMI input #2 as source 3
    Also, I had about a dozen special effects programmed, but lost all but four of them.
    Would like to connect with an experienced user or two of this unit.
    Thanks in advance for any advice and help.
  • Rudolf Bom
    May 3, 2020 at 4:57 pm
    Jeff, I am using the same box for 6 Video Sources and a Laptop for Stills etc. and combine this with a Behringer Audio Mixer X32 from which we take the L/R Signal over XLR. It works, but you have to set for all Video Sources the Audio Source to Analog (That is in the Audio/Video Setup), else you will keep listening to Audio from the Video Sources). Then further down in the Menu, you set the Audio CH to SD2 (when the XLR-Cables are on Audio IN 2), and then, you go one menu more down to Audio Fader, and set the Source to CP 12 PAIR – this sets the Faders 1/2 to Source 1 and the Faders 3/4 to Source 2 (That is Page 28 in the Manual).
    This is how I got it working.
    But: then I found out how to store Events and how to recall them, with the result that the programmed Events did not use the Audio Settings as previously programmed. Very annoying, so there is more to find out. If you are still working actively with this box (in itself it has a lot of capabilities compared to many other systems), we might get in closer contact to share experiences, the user-community for this box seems very small.
    Best, Rudolf.
