Activity Forums Panasonic Cameras can’t get around the red exclamation mark on log & transfer
  • can’t get around the red exclamation mark on log & transfer
    Posted by Andres Jimenez on June 25, 2008 at 8:24 pm
    Hello everyone, I’m having a problem with log and transfer, I use the HVX200 with an FS100, I copied the footage to an external GRaid drive and started importing with Log and transfer on FCP. Everything runs just fine except fpr the last clip on my batch. I already tried everything, shortening the name, unchecking the duplicate frames option, copying the file on a new contents folder. Nothing has worked. Does anyone know another way to get around this? I would really apreciate it.
    Roberto Battista replied 16 years, 2 months ago 4 Members · 9 Replies
  • 9 Replies
  • Shane Ross
    June 25, 2008 at 10:42 pm
    Can you play the clip in the Log and Transfer window? It might be corrupt and in need of repair. The HVX-200 has a clip repair option, as does HD Log.
    Shane
  • Andres Jimenez
    June 25, 2008 at 11:10 pm
    It plays fine on the log and transfer window so i guess the file is ok. Any other ideas?
  • Shane Ross
    June 25, 2008 at 11:14 pm
    I would still try the REPAIR option if you can.
    Shane
  • Andres Jimenez
    June 25, 2008 at 11:26 pm
    I can do this from the footage on my external drive?
  • Shane Ross
    June 25, 2008 at 11:32 pm
    If you had HD Log, yes. But if want to use the camera you need to copy the entire CONTENTS and LASTCLIP back to the P2 card and put that into the camera.
    Shane
  • Andres Jimenez
    June 25, 2008 at 11:41 pm
    I’ll do that and I will tell you how it went. Thank you
  • Andres Jimenez
    June 26, 2008 at 12:51 am
    It work out fine i copied the footage back to the firestore and the firestore has a repair clip function i used it and the problem was solved. Thank you so much.
  • Christen Marquez
    August 6, 2009 at 6:32 pm
    This thread is great. I hadn’t thought to copy the contents folder back to my firestore drive and repair the files this way.
    However after trying that, and trying to ingest in Log and Transfer I still get that red exclamation error.
    I have tried everything. Trying to ingest from a new project. Copying the contents folder to another location and ingesting from there. I have unchecked the duplicated frames. I have tried ingesting the clip using the original metadata name which is 0203FW, and then tried shortening the name to just 203. none of these things worked. Like I also said I also tried moving all of the contents folder back onto my firestore drive and doing repair clip, then i tried repair disk. All to no avail.
    I downloaded the trail version of HD log, but I guess that doesn’t have the repair clip function, and I cannot pay the $600 for the gold edition to recover the clip.
    I am hoping there is another trick to try. Thanks!
  • Roberto Battista
    July 7, 2010 at 10:58 am
    I am having the same problem and can’t find a way around it.
    The files display and play properly in the log and transfer window, they go trough the process as usual but at the end the import fails and shows the red exclamation mark.
    It is the first time I have this problem and it’s the first time I use a new camera (Panasonic 154) while I never had problems with other Panasonic cameras.
    Roberto
    ROBERTO’s:
    MULTIMEDIA https://www.robat.scl.net
    VIDEO https://www.youtube.com/robertobattista
    PHOTO https://www.flickr.com/photos/robateye/sets/
    MUSIC https://www.myspace.com/robertobattista
    MORE MUSIC https://www.robat.scl.net/content/musicpages/music.html
