Activity Forums Adobe Audition Can’t fix this word!
  • Simon Billington
    July 15, 2016 at 11:31 am
    Okay I just checked it out and on the onset it sounds like it would be tricky to fix.
    But I’ll have a closer look at it over the weekend and see if i can come up with a solution for you. Assuming its still an issue you want to get worked out
  • Simon Billington
    July 18, 2016 at 11:55 am
    Okay. It’s not perfect, these kind of repairs rarely are.
    The audio glitch is almost completely gone. Its certainly good enough for mainstream.
    10313_implementationedit.wav.zip
    It is however missing 0.24ms from the duration of the clip. It was really the only way it could be fixed. Hopefully, its not an issue. if it is there is something we can do about that too.
