Activity Forums VEGAS Pro Can’t find text editor in Vegas 8!
  • Can’t find text editor in Vegas 8!
    Posted by Clarkt on August 28, 2007 at 4:21 am
    Sony Vegas Movie Studio 8.0 Platinum:
    When I right click on the green icon on a text event in my timeline and select ‘Edit Generated Media’ nothing happens. The text editor does not open up. There are swishing lines that go straight to the bottom of the app window in a split second – as if the editor was being minimized, but where the heck is it? I can’t find it. I can’t edit my text. The text edit window does not open even when I drag & drop the media from the text Media Generator. This is driving me crazy! Somebody please help. I can’t find any clue in the online Help.
    Thanks.
    Clarkt replied 19 years ago 3 Members · 9 Replies
  • 9 Replies
  • Matt Schwartz
    August 28, 2007 at 5:57 am
    I believe I know what the problem is, which I ran into, and it is very irritating. The swishing lines that you see are the sony text edit FX window minimizing UNDERNEATH the windows status bar. Try shrinking your windows status bar to a tiny line, and you should see a bit of it sticking there; try to grab it. If you CANNOT grab it, you will have to relocate your windows status bar to the left or right side of the screen and THEN you will be able to find and grab the minimized FX window. I went nuts just like you until I thought about what was happening. Why it happened I am not sure, but believe me, it’s under the windows status bar.
  • Clarkt
    August 28, 2007 at 6:08 am
    I believe you. How do I shrink the windows status bar?
    – Clark
  • Clarkt
    August 28, 2007 at 6:14 am
    Wait a minute… you mean the Windows ‘toolbar’. I could not shrink it until I deselected ‘Lock toolbar’ on the right click menu. Now I found my text editor, just like you predicted.
    God Almighty! I was going crazy. Thanks ever so much friend.
    – Clark
  • Edward Troxel
    August 28, 2007 at 1:23 pm
    An alternate solution is to change the resolution of your monitor to a higher resolution, find the text box, move it back to the main area, and the reset your screen resolution back.
    A third solution would be to reset everything back to “factory defaults” by holding down CTRL-SHIFT while starting Vegas.
    Edward Troxel
    JETDV Scripts
  • Matt Schwartz
    August 28, 2007 at 4:10 pm
    Is there any particular reason why this happens? The fact that it is minimizing outside the vegas desktop suggest that they are all floating toolbars….any ideas?
  • Edward Troxel
    August 28, 2007 at 4:21 pm
    They ARE movable windows and can be docked with other windows (like where the explorer, media pool, effects, and transitions are located). You can put them anywhere you like.
    Edward Troxel
    JETDV Scripts
  • Clarkt
    August 28, 2007 at 4:27 pm
    …but who knew they could actually end up completely hidden from view? Throw me a curve ball why don’t you!
  • Edward Troxel
    August 28, 2007 at 4:57 pm
    Yep, just like any other window (any program you run), they can actually be moved OFF the screen! Which is USEFUL when you have multiple monitors as you may want that dialog box on the second monitor.
    Edward Troxel
    JETDV Scripts
  • Clarkt
    August 28, 2007 at 7:35 pm
    Silly me! I should have known. I was in total panic trying to make a deadline.
