Activity Forums DaVinci Resolve Cant Find Reference monitor? Using an Intensity Pro HDMI card
  • Cant Find Reference monitor? Using an Intensity Pro HDMI card
    Posted by Don Cobble on June 27, 2017 at 1:15 am
    I am one day old in DR 12.5 Studio. Got the software installed, but cannot find out how to get a reference monitor feed through my Decklink Intensity Pro HDMI Card?
    Help Please
    dc
    I7 3930K 3.2Ghz
    32 GB Ram
    SSD 850 Pro OS drive
    4x 850 EVO Raid 2TB
    3-4 TB HD
    Win 10 Pro 64bit OS
    Geforce 1080 8GB
    Brent Marginet replied 9 years, 1 month ago 3 Members · 4 Replies
  • Ole Kristiansen
    June 27, 2017 at 11:08 am
    I am using a Windows computer. First, make sure the card is properly installed in the Windows Control Panel – Hardware and Sound! Then you will see if the card is displayed in Davinci Resolve. Once you have opened Davinci Resolve, goto the upper left corner, select Davinci Resolve and Preferences.
  • Don Cobble
    June 27, 2017 at 5:25 pm
    Ole,
    That was what I needed!!!!!! Though I am not using the Intensity Pro 4K, mine is the older Intensity Pro HD 1920×1080 but I dont edit in 4K.
    Dank-Je Thank You!
    Don
  • Don Cobble
    June 29, 2017 at 7:13 pm
    Ole
    I have 1920×1080 HDMI Intensity Card.
    I have a monitor capable of 4K
    I only edit in 1920×1080 at this time
    Do you know if I would I see any : A) performance Improvement and or B) Visual Quality Improvement buying the Intensity Pro 4K card if my media is only 1920 x 1080?
    Thank U
    Don
  • Brent Marginet
    July 18, 2017 at 6:15 am
    [Don Cobble] “A) performance Improvement and or B) Visual Quality Improvement buying the Intensity Pro 4K card if my media is only 1920 x 1080?
    Resolve performance is really based on your CPU, GPU and RAM so you will be fine with the HDMI Intensity Card.
    As for Visual quality you will not see any difference unless your are working with higher res Media.
    If it were 4K Media you would not only need a 4K Card but also a 4K Monitor to really see a difference.
    \”MY MEDIA/PROJECT MOTO: If you think three copies of your media or project are enough.
    Take a moment to place a value on them and then maybe add two more.
    Hard Drives are now stupidly cheap. A RE-SHOOT AND YOUR TIME AREN\’T.\”
