Activity Forums Avid Media Composer can’t Find my audio card
  • can’t Find my audio card
    Posted by Doug Bay on May 22, 2006 at 5:10 pm
    I just changed computers now Im editing on a AMD 3200 1.5gig ram w Sound Blaster Audigy LS(24bit).
    When I install avid xpress pro 5.2.1, it says Cant find any audio card in your system. You will not be able to play audio.
    When I first installed avid it worked fine. Then I installed Quicktime (newest version) and now it says that. I have since then taken off quicktime and reinstalled my audio drivers. It still says it. Anyone have any suggestions?
    Doug Bay replied 20 years, 4 months ago 2 Members · 2 Replies
  • Alex Alexzander
    May 22, 2006 at 6:12 pm
    Go back to the Device Manager, and remove the software driver for the sound card, then reboot. Windows should re-discover the sound card all over again, and give you a pretty clean state from which to return back to normal operation.
    -Alex Alexzander
  • Doug Bay
    May 22, 2006 at 6:19 pm
    Thanks! That worked perfect!
