Activity Forums Apple Final Cut Pro Can’t find current project
  • Can’t find current project
    Posted by David Van hooser on December 25, 2016 at 10:12 pm
    Hi. I’m working with Final Cut Pro X 10.3. Fairly new to it, although I’ve used previous FCP versions for years.
    I thought Final Cut Pro X always opened the current project, or last project, by default when opening the app. Sometimes my FCP X does that, sometimes not – at which point I’ve been going to the drive itself to open the latest/current project (by date). When I attempt that now, I get a prompt telling me “the file name is invalid.” Doing the same thing I’ve done before.
    So any thoughts on finding a project? And how can I ‘set’ FCP X so that it ALWAYS pulls up the latest version of the latest project by default? Thanks for any help. This is a months-long critical project.
    Scott Witthaus replied 9 years, 4 months ago 3 Members · 4 Replies
  • Noah Kadner
    December 25, 2016 at 10:19 pm
    Project timelines are saved into Libraries. That is what you can open directly, not projects.
    Noah
    FCPWORKS – FCPX Workflow
    FCP Exchange – FCPX Workshops
    XinTwo – FCPX Training
  • David Van hooser
    December 25, 2016 at 10:41 pm
    Thanks Noah. I’m still relearning the jargon from earlier FCP times.
    Anyway, how to find/recall the Library, then Event that I need? As mentioned, I usually count on it to be there by default when reopening FCP X. Now it’s not. I don’t know how that happened, but I’ll figure out later. The main thing is finding the Library/Event I need.
    Much thanks.
  • Noah Kadner
    December 25, 2016 at 10:48 pm
    Just search for FCPX Library in the finder and start opening them.
    Noah
  • Scott Witthaus
    December 28, 2016 at 10:17 pm
    Also, if you hold the option key down while launching FCPX you will get a list of recent Libraries or the option to Locate the one you want.
    Scott Witthaus
    Senior Editor/Post Production Supervisor
    1708 Inc./Editorial
    Professor, VCU Brandcenter
