Activity Forums Adobe Premiere Pro Can’t find Auto saves
  • Can’t find Auto saves
    Posted by Malcolm Desoto on July 25, 2024 at 11:17 pm
    Hey all, just on a little treasure hunt to find where Premiere is auto saving.
    When I look at the preferences within the project, it shows:
    documents > adobe > Premiere Pro > 22 > Autosave
    However, when I navigate to that location, the file is not there. I’m searching everywhere on my system drive but can’t seem to find the file. Any ideas?
    Malcolm Desoto replied 2 years, 1 month ago 3 Members · 4 Replies
  • Dennis Dean
    July 25, 2024 at 11:44 pm
    In mine a folder called “Adobe Premiere Pro Auto-Save” is automatically created in the same folder where my project document resides.
  • Malcolm Desoto
    July 25, 2024 at 11:45 pm
    Yes, that is usually the case, but the file is not there or anywhere that I can find.
  • Ivan Eldredge
    July 25, 2024 at 11:47 pm
    Hi Malcolm,
    In the latest versions of Premiere Pro, autosave files are typically saved in the same folder where the original project was created. If you changed this setting either initially or during your work, you can find the current autosave location by going to File > Project Settings > Scratch Disks and checking under “Project Auto Save.”
    Additionally, autosave files can sometimes be found in Documents > Adobe > Premiere Pro > [Version] > Autosave folder.
    Hope this helps!
    Bye!
    Ivan Eldredge G.
  • Malcolm Desoto
    July 25, 2024 at 11:51 pm
    Hey everyone, I finally found the auto save folder on a separate drive that I use for cache files. No idea why Premiere decided to put it there as the project settings clearly indicate a different file path.
