Activity › Forums › Apple Final Cut Pro Legacy › Can’t fade with wide screen mask
Posted by Eli Mavros on May 1, 2007 at 4:23 pmIt is so odd, but has anyone noticed that you can’t put a fade on a clip (either using a transition or key framing the opacity) if there is a widescreen mask on it? Why is that? It is so lame.
Best,
EliMark Maness replied 19 years, 5 months ago 6 Members · 6 Replies -
Tom Wolsky
May 1, 2007 at 4:39 pmThis is a bug in 5.1. I presume you reported it in feedback. The more users who do the more likely it will be corrected.
All the best,
Tom
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
Stuart Ferreyra
May 1, 2007 at 7:25 pmNest the clip / sequence and add the dissolve to the new nested clip.
Just like working in AE with pre-compose assets.Stuart Ferreyra
Timecode Multimedia
President
Santa Monica, CA 90025
https://www.timecodemultimedia.com -
Tom Wolsky
May 1, 2007 at 7:40 pmIn this instance pre-comping it does not fix the problem. The functionality is broken. It should not work like that. The transition should be downstream of the effect, and works correctly in earlier versions of the application.
You can workaround this by using a four-point garbage matte, or the mask shape filter, or a Photoshop mask, anything but the widescreen filter.
All the best,
Tom
Tom Matthies
May 1, 2007 at 8:59 pmOr, in a pinch, put a slug on the top track and ramp the opacity of the slug to do the fade…kinda old school but…
tom -
Walter Biscardi
May 1, 2007 at 9:09 pm[Tom Matthies] ”
Or, in a pinch, put a slug on the top track and ramp the opacity of the slug to do the fade…kinda old school but…”This is what I do. Quite simple really.
Walter Biscardi, Jr.
HD Editorial & Animation for Food Network’s “Good Eats”
HD Editorial for “Assignment Earth”Read my blog! https://blogs.creativecow.net/WalterBiscardi
Mark Maness
May 2, 2007 at 1:32 pmI thought we all did this…
I find it very necessary when you have to fade up with CG at the same time.
_______________________________
Wayne Carey
Schazam Productions
http://www.schazamproductions.com
