Activity Forums Adobe Audition Can’t Extract Surround Channels To Mono Files
  • Can’t Extract Surround Channels To Mono Files
    Posted by Erick Stoll on July 10, 2012 at 11:35 pm
    I’m mixing my first surround mix using audition, and am going to build a dolby surround track using Compressor. I’m using Audition 5.5 on a MacPro. As I understand it, I need to export 6 discrete channel files, but for some reason, “Extract Channels To Mono Files” is greyed out. Any ideas? Thanks!
    Durin Gleaves replied 14 years, 1 month ago 2 Members · 1 Reply
  • Durin Gleaves
    July 11, 2012 at 5:15 pm
    Are you trying to use this command from within the Multitrack editing environment? If so, you would need to perform a Mixdown of your session to a single file, then choose this menu item within the Waveform editor.
    Durin Gleaves
    Adobe Audition
