Activity Forums Adobe Premiere Pro Cant export XML from FCP to PP
  • Cant export XML from FCP to PP
    Posted by Jack Bibbo on January 12, 2012 at 12:56 am
    Individual SEQ work fine. But Project XMl’s do not.
    Tried to pair down the project to a folder or two but it still gave me a generic error message
    any thoughts?
    jack
    Jeremy Garchow replied 14 years, 7 months ago 2 Members · 10 Replies
  • 10 Replies
  • Jeremy Garchow
    January 12, 2012 at 3:46 am
    I just imported an entire project the other day. Worked a treat.
    Make sure you have latest PPro. What general message do you get?
  • Jack Bibbo
    January 12, 2012 at 6:14 pm
    ” The Importer reported a generic error”
    So XML of FCP that are simple. Maybe one folder bunch of clips have worked.
    XML’s of Seq have worked.
    However this project that has tons of folders within folders with mix media all fails.
    ideas?
    thanks
    jack
  • Jack Bibbo
    January 12, 2012 at 6:20 pm
    Sorry on PPro 5.5
    8 core
    6 gigs 4.5 allocated to PPro
  • Jeremy Garchow
    January 12, 2012 at 6:22 pm
    [jack Bibbo] “Sorry on PPro 5.5 “
    5.5.2?
    There’s usually a log that gets written in to the PPro project. Anything in that log?
    Jeremy
  • Jack Bibbo
    January 12, 2012 at 6:29 pm
    Hey Jeremy,
    I am new to PPro. Our Facility is testing out the program as we are thinking about transferring from FCP.
    Where do I find that log?
    I will look in if it is 5.5 or 5.5.2
  • Jeremy Garchow
    January 12, 2012 at 6:35 pm
    [jack Bibbo] “Where do I find that log? “
    In the project in the bin named after the XML.
    Did anything come in at all?
    Make sure you update the software as I think there was changes made to XML importing.
    I am new to the software and in testing stages as well.
    Jeremy
  • Jack Bibbo
    January 12, 2012 at 7:17 pm
    hey Jeremy,
    so we are on 5.5.2
    There was no report generated.
    For another test, I ran it in reverse. PPro to FCP XML Opened my that XML in FCP and it worked great. Then saved that proj, kicked out an XML and opened it in PPro, ie went back FCP to PPPro. And that worked. Few things were wonky (offline) but essentially it worked.
    So something is up with that original FCP Project (the big one that fails) but without a report I can not see which file it is hanging up on that essentially crashes it.
    I got a report going from PPro to FCP but not from FCP to PPro. Even on the one that worked. It was not in the main folder from which I pulled the XML (like it was when I went from PPro to FCP – I saw that report and it was all there)
    not sure where that puts me…..
    j
  • Jeremy Garchow
    January 12, 2012 at 7:21 pm
    [jack Bibbo] “not sure where that puts me…..”
    Hung out to dry. Left in the cold. Up a creek, no paddle.
    Any chance you can upload the failed XML? I can try it here.
    The other thing to do would be to select a few elements (at root level) in the FCP project at a time and export those as an XML.
    If at any point one of those imports fails, perhaps you can start to narrow it down.
    Jeremy
  • Jack Bibbo
    January 12, 2012 at 9:19 pm
    nice one.
    I cant post now but will try for you. What is your email?
    I had pull just bins into a new project before it was working what made me believe it was a corrupt file.
    somewhere.
    I will keep you posted.
    bibbo
  • Jeremy Garchow
    January 12, 2012 at 11:52 pm
    Editstation ….(at)……. Gmail……dot…..the usual three letters.
