Activity Forums Adobe After Effects Can’t export with Alpha
  • Can’t export with Alpha
    Posted by Jerel Peterson on August 23, 2014 at 2:29 am
    For some reason, I now have a computer that will no longer give me the option to export a quicktime file as RGB + Alpha — that choice is grayed out no matter what project I open.
    I’ve moved the project I need asap to a similar computer, and that one DOES give me RGB + Alpha. What could be causing this?
    John Cuevas replied 12 years ago 2 Members · 2 Replies
  • John Cuevas
    August 23, 2014 at 12:42 pm
    First what codec have you selected? Also it would be helpful to post a screen shot of the output module you have selected on the computer that is not giving your a RGBA choice.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Jerel Peterson
    August 23, 2014 at 4:08 pm
    Thanks for pointing it out — for some reason, the codec was set for H264 instead of animation. It’s working now.
