Activity Forums Apple Final Cut Pro Legacy Can’t export to compressor
  • Can’t export to compressor
    Posted by David Sandbank on February 24, 2006 at 6:06 pm
    I have FCP 5 on G5 Power mac. For some reason I can’t expot my sequence to Compressor from FCP. The compressor menu is not highlighted. I tried opening Compressor from applications and it doesn’t open.
    David
    Jan Bliddal replied 20 years, 6 months ago 3 Members · 2 Replies
  • Jeremy Garchow
    February 24, 2006 at 8:21 pm
    Sounds like you need to reinstall compressor. You can can do a custom install from your FCP DVD and tell it to only install compressor.
    Jeremy
  • Jan Bliddal
    February 27, 2006 at 11:21 am
    It s a Bug in Final Cut 5. You need to Export to quicktime instead. when doing so deselect make selfcontained movie. Then export file to a location where you can find it. Open compressor, and import the file. It is now possible to use compressor.
    Let the machine work for you. Not you for the machine
