Activity Forums Adobe Premiere Pro Can’t export to Audition
  • Can’t export to Audition
    Posted by Ron Pestes on November 19, 2011 at 12:21 am
    I have a sequence open and have it active. But if I try to send it to Audition the Audition option is greyed out. Why can’t I access it?
    ronpesteshdvideo.com
    Apple Certified Master Pro FCS 2
    Sony EX-3
    MacBook Pro
    Dell M6600
    New convert to Adobe CS5.5 Production Premium
    John Graves replied 11 years, 9 months ago 6 Members · 15 Replies
  • 15 Replies
  • Jon Barrie
    November 19, 2011 at 3:02 am
    Are you going via:
    Edit> Edit in Adobe Audition>Sequence…
    While the Timeline Panel is active (orange edge)
    Cheers JB
    Jon Barrie
    Adobe Video Solutions Consultant ANZ
    Jon’s YouTube Tutorial Page
    follow Jon with twitter
  • Ron Pestes
    November 19, 2011 at 3:11 am
    Yes, but after I click on “Edit” the “Edit in Audition” part is greyed out and I can’t click on it.
    Sony EX-3
    MacBook Pro
    Dell M6600
  • Jon Barrie
    November 19, 2011 at 6:15 am
    Has it worked before?
    If you have Prod Premium it should talk to one another, it may not if you have installed separate PPro and Audition Serials.
    – JB
    Jon Barrie
  • Ron Pestes
    November 19, 2011 at 4:05 pm
    This is the first time I have tried to use it. I installed from one download for all components. I am just coming over from FCP so I like what I see except for a few minor problems.
    Sony EX-3
    MacBook Pro
    Dell M6600
  • Gary Huff
    November 19, 2011 at 9:28 pm
    Is Audition even installed? Can you bring it up and it runs properly?
  • Ron Pestes
    November 20, 2011 at 5:01 am
    Yes, it is installed. I can use it with just linking a single clip over to it but not a sequence. This is the first time I have used it and it was installed as a part of the Production Premium Suite.
    Sony EX-3
    MacBook Pro
    Dell M6600
  • Gary Huff
    November 20, 2011 at 4:03 pm
    [Ron Pestes] Yes, it is installed. I can use it with just linking a single clip over to it but not a sequence. This is the first time I have used it and it was installed as a part of the Production Premium Suite.
    Ron, it would have been helpful if you had stated you were trying to send a nested sequence into Audition instead of the ambiguous description you used in your initial post.
    You can’t do that in Premiere yet. You’ll have to export the audio from the sequence, open it in Audition, and apply your effects. Clunky, but doable.
  • Ron Pestes
    November 20, 2011 at 5:04 pm
    I am not sending a nested sequence. Where did you get that idea? It is just a sequence from the timeline that I have been working on.
    Sony EX-3
    MacBook Pro
    Dell M6600
  • Gary Huff
    November 20, 2011 at 5:19 pm
    My apologies. This sounded like you were trying to send it audio from a nested sequence.
    Can you explain exactly what it is you’re clicking on? Are you trying to select a bunch of clips in the sequence to export?
  • Ron Pestes
    November 20, 2011 at 5:31 pm
    I have tried two ways. I highlight the sequence in the project window and click on “edit” then go down to the edit in Audition option or I make sure the timeline is active and do the same thing. Both ways the option to send to Audition is greyed out.
    Sony EX-3
    MacBook Pro
    Dell M6600
