Activity Forums Apple Final Cut Pro Legacy Can’t export to 16:9 Quicktime from HD sequence
  • Can’t export to 16:9 Quicktime from HD sequence
    Posted by Matt Coursey on September 22, 2005 at 5:56 pm
    Hi there,
    I’m using Final Cut 4.5 and Quicktime 7. I created a lovely little animation using a DVCPRO HD 720p 60 sequence and Boris titles. It looks and runs fine in FCP.
    I’m trying to export it to Quicktime file. But when ever I do it converts the file to 4:3 aspect ratio. I’ve tried several codecs PNG, TIFF, JPG, Animation, H.264, with the same results. I also tried setting a custom size of either 960×720 or 480×360, also no luck.
    Has anyone had a similar problem or know what I might be doing wrong?
    Thanks lots.
    Matt
    Matt Coursey replied 21 years ago 2 Members · 2 Replies
  • Jeremy Garchow
    September 23, 2005 at 1:13 am
    That’s because DVCPRO HD native footage is 960×720. It is recorded anamorphic to conserve bandwidth. It’s one the reasons we can now edit HD on laptops. The correct 16:9 aspect ratio is 1280×720. Try exporting your quicktime changing the size to 1280×720.
    G5 Dual 2Ghz <> 4GB RAM <> FCP 5.02 <> Kona 2
    ATTO 42XS <> Huge Systems 1.25 TB 4105 Fibre
  • Matt Coursey
    September 23, 2005 at 6:03 pm
    Hey, thanks.
    I don’t know what happend to my math skills.
    960×720 is clearly not 16:9
    Thanks again.
