Activity › Forums › Avid Media Composer › Can’t export OMF from 1080p 23.98 sequence. Help
  • Can’t export OMF from 1080p 23.98 sequence. Help
    Posted by Dan Riley on February 21, 2008 at 7:33 pm
    If we open 29.97 SD projects, highlight the sequence, we can go to the file menu, options button, and export OMF 2.0. But if we open our 1080p 23.98 project, go a sequence and do the same thing, there is no OMF export options, only AAF and other audio options. How do we get this export to work and make an OMF 2.0?
    Dan
    Rory Brennan replied 18 years, 7 months ago 2 Members · 1 Reply
  • Rory Brennan
    February 22, 2008 at 6:32 pm
    We’ve had this too. Very annoying. Either convince your sound dept. to purchase a plug-in for aaf or do what we do.
    – Duplicate sequence into new bin.
    – Delete video track/s (can’t remember if this is entirely necessary)
    – Select sequence in new bin. Select CLIP>MODIFY and change sequence format to SD 23.98
    – Close project. Open new SD 23.98 project.
    – Open bin from HD project in the new SD project.
    – Export OMF as per usual.
    Hope this helps.
    RB
