Activity Forums Avid Media Composer Can’t export Mpeg2 from Symphony
  • Can’t export Mpeg2 from Symphony
    Posted by Jaymin Patel on May 20, 2005 at 3:30 pm
    Hi, i’m running Avid symphony 5.0.5 on a pc with windows 2000 SP4. everytime i try to export a sequence as an mpeg2 i get an error saying “could not initialize authorscript.” i talked to avid tech support and they had a cheezy fix where you move some files out of the avid folder and then copy them back in. the fix worked for a while and then stopped. when i recently upgraded symphony to 5.0.5, the mpeg2 function worked for a while…and then stopped. does anyone know a way to fix this or a good workaround to make a dvd? any help would be greatly appreciated. thanks.
    jaymin
    Donato M. rondinelli replied 21 years, 4 months ago 2 Members · 1 Reply
