Activity › Forums › Adobe Premiere Pro › Can’t export large frame size in Premiere Pro using H264 codec
  • Can’t export large frame size in Premiere Pro using H264 codec
    Posted by Lance Miller on September 15, 2016 at 6:09 am
    Hey folks,
    I have a client that needs an export with 2000×3000 frame size.
    The sequence in Premiere Pro is 2000×3000 but when I try to export it shrinks to 1536×2304. I can click “Match Sequence Settings” but it creates a large Quicktime file (4GB).
    I need a small file for the web, like H264.
    Attached photo, any suggestions?
    Lance
    Daniel Waldron replied 10 years ago 3 Members · 4 Replies
  • Tero Ahlfors
    September 15, 2016 at 8:24 am
    That’s the largest resolution H264 supports for the height. More info here: https://en.wikipedia.org/wiki/H.264/MPEG-4_AVC#Profiles
  • Lance Miller
    September 15, 2016 at 9:00 am
    Thanks for your response Tero! Is there any way to decrease the file size? Are there any web friendly codecs that work with those dimensions?
  • Tero Ahlfors
    September 15, 2016 at 9:32 am
    I don’t know what file the player in question is expecting but you could render it out as 3000×2000 and see if you can rotate the video in the player.
  • Daniel Waldron
    September 15, 2016 at 7:06 pm
    You’ll probably want H.265, but you want to double-check that will work with where ever you are delivering it.
