Activity › Forums › Adobe Premiere Pro › Can’t export higher than 4K
Posted by Sa Dilshan on September 10, 2019 at 6:06 amTero Ahlfors replied 6 years, 11 months ago 3 Members · 5 Replies -
Shane Ross
September 10, 2019 at 6:31 amWhat are your project settings? 4K? Or higher?
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Tero Ahlfors
September 10, 2019 at 6:42 amYour H264 level is probably too low. https://en.wikipedia.org/wiki/Advanced_Video_Coding#Levels
Sa Dilshan
September 10, 2019 at 6:50 amThank You. Are there any solution? I tried RAW files from different cameras. But got the same result.
Tero Ahlfors
September 10, 2019 at 7:42 am[Sa Dilshan] “Are there any solution?”
Use a high enough H264 level that can output the resolution you need. Or export to a format that doesn’t have those kind of restrictions.
